defjam
Rep Power: 0 ![]() |
I have a few plots where I am trying to show the edge of the microstructure however there are horizontal lines that fill in the area of interest for my needs. Is there a way to remove these horizontal lines without getting rid of the outline of the microstructure?
run_9_5_2_pressure_000035.png |
Scott Fowler
Rep Power: 17 ![]() |
I'm not sure we can offer helpful advice without knowing more about your data. I'm going to guess that the micro structures (including the horizontal lines) are simply part of your grid and there's not likely much that can be done.
If you have active maintenance, you can contact our support staff for more help. Last edited by wsfowler; September 25, 2023 at 00:45. |
plotting |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 03:21 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
