Home > Forums > Visualization & Post-Processing Software > Tecplot
Problem with XY plot
Old   August 15, 2023, 05:26
Default Problem with XY plot
Ehab Sabry Rashed
EhabSabry14 is on a distinguished road
Hello everyone,
I have solved a 3d CFD case and I am trying to get the data of temperature along z axis at the final time step only. Check the attached image please.
Any ideas?
EhabSabry14 is offline   Reply With Quote
Old   August 24, 2023, 08:19
jawahar sivabharathy
sjsivabharathy is on a distinguished road
Hi Rashed,
There is no image attached.
There are two options that I'm aware of
1) You can draw a line and use extract data option in Tecplot.
2) a) Create a file which has only co-ordinates (x,y,z) like xyz.txt
b) Import the file in tecplot
c) It will as a new zone
b) Then use interpolate option from zone (whatever) to the new imported zone
Hope this helps.
Thanks,
Jawahar.
sjsivabharathy is offline   Reply With Quote
converge, tecplot 360
plot problem Danial1992 FLUENT 0 May 12, 2017 03:24
A problem on the Energy spectrum plot by using FFT Martin duan OpenFOAM Post-Processing 5 February 22, 2016 11:12
[stressAnalysis] Residual plot for OpenFOAM-ext problem. Sargam05 OpenFOAM CC Toolkits for Fluid-Structure Interaction 26 July 14, 2014 09:36
X-Y plot problem, please help tobytoby FLUENT 8 March 20, 2013 21:57
CFD post vector plot problem bharath CFX 3 February 8, 2011 18:16
