Home > Forums > Visualization & Post-Processing Software > Tecplot
Problem in calculating vortex using Q criterion
Old   July 2, 2023, 23:33
Default Problem in calculating vortex using Q criterion
Zhang
Amber0922 is on a distinguished road
Hi, everyone
I am currently conducting calculations for the backward facing step and intend to plot the vortex using Q criterion. I have set the mean velocity in x, y, and z directions under 'Analyze - Field Variable' and selected 'Q criterion' under 'Calculate Variables'. Subsequently, I have set the Iso-Surface as Q with a value of 300.
However, my results appear anomalous as they depict a ring-like structure instead of conforming to expected outcomes. Could you please advise if there are any errors in my operations? Thank you for your assistance.
Amber0922 is offline   Reply With Quote
Old   August 24, 2023, 02:32
jawahar sivabharathy
sjsivabharathy is on a distinguished road
Hi Amber,
I think the value of Q you have set is too high.
Did you try for lower values? Please give more details about the
solver you used for computing the flow and the Reynolds number.
Also did you look at the streamlines and vorticity field?
Please refer to my work where the flow structures are identified
via Q criterion using Tecplot.
1) https://www.cambridge.org/core/journ...9B75CD#article
2) https://www.cambridge.org/core/journ...3385E1#metrics
3) https://pubs.aip.org/aip/pof/article...tion-bubble-in
Regards,
Jawahar.
sjsivabharathy is offline   Reply With Quote
Problem in calculating additional variable with second time derivative ziyixy CFX 1 April 24, 2021 23:01
getting problem in calculating torque required for centrifugal pump sarfarazii Main CFD Forum 1 September 9, 2015 05:59
Problem of calculating divergence due to wrong boundary vaule of finite area mesh lzhou OpenFOAM Programming & Development 2 June 18, 2015 06:10
[ICEM] low edge criterion value problem mraxx ANSYS Meshing & Geometry 6 April 30, 2013 10:03
Problem: calculating drag coefficient RFH_student FLUENT 3 February 8, 2011 09:36
