Home > Forums > Visualization & Post-Processing Software > Tecplot
Remove Date from Header in a frame
Old   May 16, 2023, 06:33
Default Remove Date from Header in a frame
Saif Ustad
saifustad is on a distinguished road
360 User's Manual.pdf
If you go to frame details there is an option for turning on frame header. However i want to remove the date from this header. I saw in the user manual by changing the defaults in the configuration file but i dont know how to do that.
Any help you guys
i have attached the snipped of the manual that says about the above mentioned. Please let me know
saifustad is offline   Reply With Quote
Old   May 22, 2023, 18:49
Brandon M
Brandon_CFD is on a distinguished road
You can find the Scripting Guide on our website under the Tecplot 360 header here:
https://www.tecplot.com/documentation/
And find more information on the $!GLOBALFRAME command in the Scripting Guide.
The Tecplot configuration file is located in the Tecplot 360 installation directory, and it is called tecplot.cfg. That file is where the $!GLOBALFRAME command can be edited.
If you have further questions, please reach out to support@tecplot.com.
Brandon_CFD is offline   Reply With Quote
frame, frame header, tecplot, tecplot 2021r2, tecplot360
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation 101 September 21, 2011 06:37
Problems about compiling OF1.5.x on Bluegene/P ywang OpenFOAM 1 August 25, 2011 06:22
OpenFoam 1.6-ext - error ./Allwmake in /src preibie OpenFOAM Installation 14 June 14, 2011 06:57
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
