Home > Forums > Visualization & Post-Processing Software > Tecplot
Temperature contour for unstructured mesh
Old   February 27, 2023, 16:29
Default Temperature contour for unstructured mesh
Pegah
PegahMhr is on a distinguished road
Hello everybody,
I used ANSYS-CFX to simulate the flow field inside the tube array. X, Y, Z, and Temperature were extracted from CFD-Post besides "Line and Face connectivity". I analyzed the temperature and now need to visualize the data as a temperature contour. How can I show the temperature contour using Tecplot or Matlab?
attached is the data I need to be visualized using Tecplot or anything else.
Thanks.
export.txt
PegahMhr is offline   Reply With Quote
Mapping wall temperature result by energy-plus to Fluent mesh cells jimmy871013 Fluent UDF and Scheme Programming 5 March 9, 2018 13:35
the problem that gradually change of temperature contour in coal gasification bluenail FLUENT 0 November 10, 2014 03:41
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
