Need help loading transient data from a single Tecplot file |
November 29, 2022, 15:25 |
Nikolaos Beratlis
Rep Power: 16 |
I want to read transient data from a single .plt file as shown below:
VARIABLES = "X", "Y", "Z", "U", "V", "W","FX", "FY", "FZ" ZONE I= 11, T="0001", DATAPACKING = POINT, SOLUTIONTIME= 0.34874 -0.0010000 0.0250000 0.0250000 0.0000000 0.0000000 0.0000000 -0.0000000 0.0000009 0.0000106 0.0090000 0.0250000 0.0250001 -0.0000000 0.0000001 0.0000003 -0.0000000 -0.0000037 0.0000223 0.0190000 0.0250000 0.0250004 -0.0000000 0.0000000 0.0000009 -0.0000000 -0.0000108 0.0000265 0.0290000 0.0250000 0.0250007 -0.0000000 0.0000001 0.0000016 -0.0000000 -0.0000123 0.0000301 0.0390000 0.0250000 0.0250011 -0.0000000 0.0000003 0.0000025 -0.0000000 -0.0000014 0.0000265 0.0490000 0.0250000 0.0250014 -0.0000000 0.0000004 0.0000035 -0.0000000 0.0000091 0.0000287 0.0590000 0.0250000 0.0250016 -0.0000000 0.0000003 0.0000047 -0.0000000 0.0000073 0.0000283 0.0690000 0.0250000 0.0250018 -0.0000000 0.0000001 0.0000061 -0.0000000 -0.0000060 0.0000280 0.0790000 0.0250000 0.0250018 -0.0000000 0.0000002 0.0000079 -0.0000000 -0.0000120 0.0000264 0.0890000 0.0250000 0.0250018 -0.0000000 0.0000003 0.0000098 -0.0000000 -0.0000045 0.0000219 0.0990000 0.0250000 0.0250018 -0.0000001 0.0000002 0.0000116 0.0000040 0.0000003 0.0000095 ZONE I= 11, T="0001", DATAPACKING = POINT, SOLUTIONTIME= 0.70678 -0.0010000 0.0250000 0.0250000 0.0000000 0.0000000 0.0000000 -0.0000000 -0.0000010 0.0000046 0.0090000 0.0250000 0.0250001 -0.0000000 0.0000000 0.0000003 -0.0000000 -0.0000039 0.0000111 0.0190000 0.0250000 0.0250003 -0.0000000 0.0000000 0.0000010 -0.0000000 -0.0000053 0.0000141 0.0290000 0.0250000 0.0250008 -0.0000000 -0.0000001 0.0000016 -0.0000000 -0.0000055 0.0000122 0.0390000 0.0250000 0.0250014 -0.0000000 -0.0000002 0.0000021 -0.0000000 -0.0000051 0.0000133 0.0490000 0.0250000 0.0250022 -0.0000000 -0.0000001 0.0000030 -0.0000000 -0.0000024 0.0000140 0.0590000 0.0250001 0.0250031 -0.0000000 0.0000000 0.0000049 -0.0000000 -0.0000019 0.0000139 0.0690000 0.0250001 0.0250041 -0.0000000 0.0000001 0.0000074 -0.0000000 -0.0000007 0.0000145 0.0790000 0.0250001 0.0250052 -0.0000000 0.0000002 0.0000100 -0.0000000 0.0000025 0.0000157 0.0890000 0.0250002 0.0250064 -0.0000000 0.0000003 0.0000129 -0.0000000 0.0000075 0.0000183 0.0990000 0.0250002 0.0250076 -0.0000001 0.0000005 0.0000162 0.0000036 0.0000037 0.0000090 |
November 29, 2022, 19:19 |
Brandon M
Rep Power: 7 |
Hello Nikolaos,
It looks like you have 3D data here--how are you wanting to view this data? Do you want to see all the points all at once or one time step at a time and move from one solution time to the next? If you want one time step at a time, then multiple zones is required (at least one zone per solution time). Also, just for clarity, the .plt is a binary file format--this looks like ascii format, so you can save the data file with a .dat extension. |
November 29, 2022, 22:04 |
Nikolaos Beratlis
Rep Power: 16 |
I want to see the data one time step at a time. I think I was able to read them and view them in 2D mode, but in XY plot I can't animate in time. Yes, this is indeed an ASCII file and it can be .dat file extension.
November 30, 2022, 16:02 |
Brandon M
Rep Power: 7 |
The XY Line mode doesn't allow stepping through multiple time steps--that is only available via 2D or 3D Cartesian mode. You can plot a similar line in 2D mode by turning on the mesh layer if you want to visualize each plot per time step.
If you want some further insights and more specifics, email support@tecplot.com. Do you have any other questions? |
transient |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 03:52 |
OpenFoam "Permission denied" and "command not found" problems. | iyidaniel@yahoo.co.uk | OpenFOAM Running, Solving & CFD | 11 | January 2, 2018 06:47 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
