Home > Forums > Visualization & Post-Processing Software > Tecplot
2D plot of temperature and velocity
Old   October 13, 2022, 13:04
Default 2D plot of temperature and velocity
Bob
BigBoBy is on a distinguished road
Hello
I am relatively new in Tecplot. Therefore, the question is probably relatively simple. I have made a section through a 3D body (3D Fluiddomain). In the section plane I have the contour of the temperature displayed. Additionally I want to display the velocity vectors in that plane. But only the velocity in the y-z plane. I do not understand which vector variables I must select for it (U;V;W). Or how can I set the U vector to 0? Maybe this picture will help you with my problem.
BigBoBy is offline   Reply With Quote
Old   October 17, 2022, 13:35
Scott Fowler
wsfowler is on a distinguished road
To plot vectors you need the individual vector components. These are usually named something like: "U", "V", "W" or "X-Velocity", "Y-Velocity", "Z-Velocity". These should be assigned to the U,V,W fields in the Vector Details dialog.
So in your case I'd switch to the 2D Plot Type and assign Z & Y to the X- and Y-axes respectively. In 2D you only need to assign U&V vector components as well. So in your case I'd assign the "Z Velocity" vector component to U and and "Y Velocity" vector component to V.
I hope this helps.
Scott
wsfowler is offline   Reply With Quote
post procesing, tecplot, velocities
Import .csv - velocity profile - error eSKa CFX 9 April 3, 2021 14:38
Outlet temperature to temperature boundary condition of velocity inlet. (UDF) dillon Fluent UDF and Scheme Programming 3 March 25, 2018 12:06
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 03:13
