December 8, 2021, 04:56 |
Error with Fluent variable names
Adithya
Rep Power: 5 |
Hi
I Import native Fluent .cas and .dat files to Tecplot But, my variable names are not loaded. The variables show as a number. How do I correct this and get variable name? |
December 13, 2021, 12:43 |
Scott Fowler
Rep Power: 17 |
This issue has been improved over time in Tecplot 360, so try the most current release for best results. The Tecplot 360 Fluent loader is dependent on a file that Ansys provides to us to translate variable numbers to names, unfortunately the file they provide isn't perfect - so there may still be issues in the most current Tecplot 360 release.
Note that Tecplot 360 2021 R1 and newer also now includes a Fluent Common Fluid Files reader which can read .cas.h5 and .dat.h5 files. |
fluent, tecplot, variable name |
Fluent UDF urgent! Variable reaction rate | natantyt | Fluent UDF and Scheme Programming | 8 | October 17, 2021 04:35 |
Ansys Fluent Meshing Problem: Conflicting zone names | SimonWjp | FLUENT | 0 | November 8, 2016 11:38 |
how can i get valid variable names in fluent profile | henry_lu | Fluent UDF and Scheme Programming | 1 | April 23, 2011 14:21 |
Tecplot Variable Names For Fluent Data Files | Simon | FLUENT | 0 | September 22, 2005 11:44 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 04:27 |
