Rep Power: 5 ![]() |
I am trying to visualise a plot 3D grid file on tecplot. The mesh was generated using ICEM CFD 2020 and saved in plot 3D format. Just a note: the file extension from ICEM was '.fmt'. I changed this extension to '.xyz' to import it into tecplot. As you can see in the image attached, the loaded mesh file appears very distorted and am not sure why. Any guidance on this would be appreciated |
Carlos Lemes
Rep Power: 0 ![]() |
This distortion when viewing the mesh in Tecplot may be related to the axis scales being auto-adjusted.
To solve this issue, do the following (Tecplot 2019): 1. Select the menu Plot>Axis... 2. In the pop-up window, click on "X" to select the x-axis (on top of the window); 3. On the "Range" tab: 3.1. in "Dependency", select "XYZ dependent";4. click on the "Y" and "Z" from step 2 just to see if they are alredy configured. If not, ajust them. 5. click "Close" on the bottom and you're done. Last edited by CarlosLmes; July 12, 2023 at 07:23. |
Mesh Visualisation: Showing every 5th grid point | TomWaits | Tecplot | 1 | August 26, 2019 12:43 |
Tecplot 360 2013R1 Prism Grid boundary error | maxHu | Tecplot | 1 | December 13, 2018 17:14 |
Grid Cut Plane with 3D Elements in Tecplot | kagoc8 | Tecplot | 1 | August 24, 2018 11:53 |
Dynamic Mesh resulting in Curved Grid Lines | adubois | FLUENT | 3 | April 17, 2014 10:06 |
Patch grid with tecplot | Hoarau Yannick | Tecplot | 0 | October 10, 2005 11:16 |
