Home > Forums > Visualization & Post-Processing Software > Tecplot
Write .plt file without tecio
Old   July 16, 2021, 13:30
Default Write .plt file without tecio
Chunheng Zhao
zchmacchiato is on a distinguished road
I am trying to write the binary .plt file without tecio using fortran. With the help of the data format guide, I am still confused about the header part and the connection part. It is hard to follow the instruction at the end of the guide, so I want to find some help here.
I paste my code here, it is written by mpiio. I check the data format and compare it with the .plt file by preplot, the .plt file by preplot give REAL4, but mine is REAL8. They all give the right numbers. However, the header of mine is very different with preplot version.
subroutine MPIoutput
      integer::i,j,filesize,Status(MPI_STATUS_SIZE),filetype,count
      integer::nproc,cart_comm,ierr,fh,datatype
      INTEGER(KIND=MPI_OFFSET_KIND) offset
      integer,dimension(dim):: start
      character:: zonep*100,version*9,para*100
      !I GIVE THE HEADER PART value HERE
      version='#!TDV112'//char(0)
      para='VARIABLES="x","y","u","v","phi1","phi2","phi3","con","p","rho","pp"'//char(0)
      write(zonep,'(A,I3,A,I3,A)')'ZONE I=',nx+1,' J=',ny+1
      do j=local_start(2),local_end(2)
         do i=local_start(1),local_end(1)
            xx(i,j)=(i+0.d0)/nx
            yy(i,j)=(j+0.d0)/ny
         enddo
      enddo
      start=(/ghost,ghost/)
      offset=0
      If( rank == 0 ) Then
         Call mpi_file_delete( 'out.dat', MPI_INFO_NULL, ierr )
      End If
      Call mpi_barrier( mpi_comm_world, ierr )
      call MPI_TYPE_CREATE_SUBARRAY(2,local_length+2*ghost,local_length,start,MPI_ORDER_FORTRAN,&
      MPI_DOUBLE_PRECISION,datatype,ierr)
      call MPI_TYPE_COMMIT(datatype,ierr)
      call MPI_TYPE_CREATE_SUBARRAY(2,global_length,local_length,local_start,MPI_ORDER_FORTRAN,&
      MPI_DOUBLE_PRECISION,filetype,ierr)
      call MPI_TYPE_COMMIT(filetype,ierr)
      call MPI_File_open(MPI_COMM_WORLD,'out.dat', &
      MPI_MODE_WRONLY + MPI_MODE_CREATE,MPI_INFO_NULL,fh,ierr)
!WRITE THE HEADER PART
      if(rank.eq.0)then
         call MPI_File_seek (fh,offset,MPI_seek_set,ierr)
         call MPI_File_write(fh,trim(version),len(trim(version)),MPI_char,status,ierr)
         call MPI_File_write(fh,trim(para)  ,len(trim(para)),MPI_char,status,ierr)
         call MPI_File_write(fh,trim(zonep)  ,len(trim(zonep)),MPI_char,status,ierr)
      endif
      offset=len(trim(version))+len(trim(para))+len(trim(zonep))
      call MPI_File_set_view(fh,offset,MPI_DOUBLE_PRECISION,filetype,&
      "native",MPI_INFO_NULL,ierr)
!WRITE THE DATA PART
      CALL MPI_FILE_WRITE_all(fh, xx, local_length(1)*local_length(2), MPI_DOUBLE_PRECISION, MPI_STATUS_ignore, ierr)
      CALL MPI_FILE_WRITE_all(fh, yy, local_length(1)*local_length(2), MPI_DOUBLE_PRECISION, MPI_STATUS_ignore, ierr)
      CALL MPI_FILE_WRITE_all(fh, ua   ,1, datatype, MPI_STATUS_ignore, ierr)
      CALL MPI_FILE_WRITE_all(fh, va   ,1, datatype, MPI_STATUS_ignore, ierr)
      CALL MPI_FILE_WRITE_all(fh, phi1 ,1, datatype, MPI_STATUS_ignore, ierr)
      CALL MPI_FILE_WRITE_all(fh, phi2 ,1, datatype, MPI_STATUS_ignore, ierr)
      CALL MPI_FILE_WRITE_all(fh, phi3 ,1, datatype, MPI_STATUS_ignore, ierr)
      CALL MPI_FILE_WRITE_all(fh, con  ,1, datatype, MPI_STATUS_ignore, ierr)
      CALL MPI_FILE_WRITE_all(fh, p    ,1, datatype, MPI_STATUS_ignore, ierr)
      CALL MPI_FILE_WRITE_all(fh, rho  ,1, datatype, MPI_STATUS_ignore, ierr)
      CALL MPI_FILE_WRITE_all(fh, pp   ,1, datatype, MPI_STATUS_ignore, ierr)
      call MPI_File_close(fh,ierr)
      call MPI_BARRIER(CART_COMM,ierr)
   endsubroutine MPIoutput
This is the error information, it says invalid header.
zchmacchiato is offline   Reply With Quote
binary file, fortran 90, mpi libraries, mpi parallel, tecplot 360
[openSmoke] LaminarSMOKE compilation error mdhfiz OpenFOAM Community Contributions 8 July 2, 2024 11:32
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 ordinary OpenFOAM Installation 19 September 3, 2019 19:13
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
