Tecplot Error: Assertion trap in function call from an add-on |
May 5, 2021, 02:25 |
Asher
Rep Power: 6 |
I'm executing a CFD simulation in Converge CFD, and the output files are in *.h5 format. When I try to load these output files into Tecplot, it throws an error stating, "Assertion trap in function call from an add-on", kindly ref. the attached screenshot. Please help. Regards, Asher |
May 10, 2021, 12:24 |
Scott Fowler
Rep Power: 17 |
Asher,
This is a bug that may have been fixed in a newer version. I know that we had an issue where CONVERGE files could be exported with boundaries that contained zero points - a condition we were not expecting. What version of Tecplot 360 or Tecplot for CONVERGE are you using? If it's not the most current, please try updating. If the issue persists, please contact us at support@tecplot.com and we'll get you sorted. Thanks, Scott |
May 6, 2023, 10:45 |
#3 | |
Ying Feng
Rep Power: 4 |
May 6, 2023, 13:00 |
Scott Fowler
Rep Power: 17 |
If you’re having problems loading CONVERGE data, please reach out to our support staff at support@tecplot.com. We’ll need to know which version of Tecplot 360 you’re using and may need an example data file from you so we can diagnose the issue.
Thanks, Scott Fowler Tecplot 360 Product Manager |
May 16, 2023, 08:36 |
Cheng Yu Che
Rep Power: 4 |
I also have same problem, I use version is EX 2022 R2. Can you help me ? Below is my error message.
https://lurl.cc/NHsgz |
May 16, 2023, 17:40 |
Scott Fowler
Rep Power: 17 |
Cheng,
It looks like you've contacted our support staff. We'll assist you through our standard support process. For others encountering issues like this - if you're not using the most recent version of Tecplot 360, we suggest that you update as there may be fixes. If the newest version of Tecplot 360 does not solve the issue, contact our support staff at support@tecplot.com. We may need you to share your data so we can diagnose the issue. Thanks, Scott |
Any experts on FFTW? | jinhua2015 | Main CFD Forum | 3 | May 22, 2022 20:44 |
Compiling User Fortran with CFX 14.0 on Win64 | Raijin Thunderkeg | CFX | 29 | March 9, 2016 12:45 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 07:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
