Home > Forums > Visualization & Post-Processing Software > Tecplot
Flow visualization at overset mesh interface
Old   December 25, 2020, 10:36
Default Flow visualization at overset mesh interface
Jim
haizhou0410 is on a distinguished road
Hi everyone,
I use star-ccm+ overset mesh method to do flow simulations with motions. I found that the flow e.g. vorticity plot at the overset mesh interface has some problems. It seems that not all unwanted cells are blanked. I use tecplot value blanking and use the "blank entire cells when 'primary value is blanked' "option and blanked the cells when overset cell status equal to 1, -1, -2 which corresponding to inactive, acceptor that is used as donor and acceptor respectively. But it still has problems with the interface which are shown in the picture. Does anyone know how to deal with this? Thank you very much in advance!
haizhou0410 is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
How to make a smooth interface for multiphase flow with dynamic mesh? aegean333 OpenFOAM Programming & Development 0 May 10, 2013 06:34
