November 10, 2020, 14:51 |
Velocity Magnitude not showing results
PENANG
Rep Power: 9 |
I need some help. I am having problems in displaying the velocity magnitude for pitching airfoil within tecplot. I imported fluent. cas and .dat files. I have tried both methods, creating new variables and secondly using velocity magnitude equations. There are two methods, which are described below: General method (works in Tecplot 360 and Focus) In this method, the mathematical definition of vector magnitude is entered and the calculated result is stored in a new variable. After loading your data, do the following: Go to Data > Alter > Specify Equations and enter the following equation: {Velocity Magnitude} = sqrt({U}**2+{V}**2) Click Calculate Using the CFD Analyzer (only works in Tecplot 360) In this method, the velocity magnitude calculation is performed by the CFD Analyzer and the calculated result is stored in a new variable. After loading your data, do the following: Go to Analyze > Field Variables Under Convective Variables, Select the Velocity option, click the Select button, and choose the velocity variables, where U, V, and W, are the X, Y, and Z components of velocity, respectively. Go to Analyze > Calculate Variables Click the Select button, select Velocity Magnitude from the list, and click OK. SOURCE TECPLOT THE Problem is I am not getting anything in my velocity magnitude, rest of the contours are providing their results, like pressure, vorticity etc. The velocity magnitude is not providing anything. I am attaching some pictures from the results and components for velocity that I have. I appreciate any help provided. Thank you. Last edited by musa19; November 10, 2020 at 19:10. |
November 19, 2020, 00:49 |
Scott Fowler
Rep Power: 17 |
A few questions come to mind.
If you still can't figure it out, contact support@tecplot.com. Thanks, Scott |
UDF comilation error. urgent help please | m zubair | Fluent UDF and Scheme Programming | 4 | February 10, 2019 12:19 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 09:35 |
Volume Fraction & Velocity Magnitude | alven299 | FLUENT | 1 | September 4, 2010 03:30 |
formula for velocity magnitude | Hai Duc | FLUENT | 0 | January 9, 2008 08:39 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 03:13 |
