Home > Forums > Visualization & Post-Processing Software > Tecplot
Streamtraces originating at one point only
Old   September 23, 2020, 18:37
Default Streamtraces originating at one point only
PENANG
musa19 is on a distinguished road
Hi, I am trying to visualize the sreamlines in techplot. I watched few video tutorials and I exported the data from fluent solution to techplot. However, the streamlines are originating from a single point. The should be like the inlet velocity over the wing surface.
I need some help. Thank you.
musa19 is offline   Reply With Quote
Old   September 23, 2020, 20:30
novedevon is on a distinguished road
Quickly it looks like that the vector variables are assigned to the grid variables rather than velocity components. To verify go to Plot> Vector in 2020R1 or Plot>Vector> Variables in previous releases and ensure that you have velocity variables assigned.
novedevon is offline   Reply With Quote
Old   September 24, 2020, 01:07
PENANG
Hi Novedevon, Thank you for your reply. Yes I understand your point. I had tried both. First I selected velocity components, but when I am tracing streamlines, no lines are formed. The lines are forming only on selecting cordinates but wrong lines are forming. Can you please explain what may be the reason. Thank you.
Old   September 24, 2020, 13:07
Velocity values on the surface are likely 0 due to a no-slip condition if no lines are formed. In 2020R1 Tecplot added no-slip streamlines which get velocity from an adjacent volume zone, give downloading the new version a shot.
Old   September 24, 2020, 13:15
PENANG
Thank you Novedevon, I will surely give it a try.
Another issue I am facing is about slices. When I am creating a slice (surface or volume), only a line is created. A whole surface slice is not forming. Can you please help in this regard. Thank you.
Old   September 25, 2020, 18:17
To give the correct answer here I think you should contact support at Tecplot.com because there could be many things causing this issue.
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" ds4719 Main CFD Forum 14 February 18, 2022 19:05
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
UDF for searching the closest point to a certain point princekar Fluent UDF and Scheme Programming 2 April 26, 2015 05:53
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 04:44
matching variable data with grid point data anfho OpenFOAM Programming & Development 0 May 6, 2011 16:28
