Home > Forums > Visualization & Post-Processing Software > Tecplot
Load *.xyz file with pyTecplot
Old   July 18, 2020, 16:34
Smile Load *.xyz file with pyTecplot
Oscar Alvarez
Sprinkles is on a distinguished road
I am trying to load a *.xyz file along with it's function file *.fun using pyTecplot.
These load fine using the command prompt and when I just load them using Tecplot.
This is what I have
import logging
logging.basicConfig(level=logging.DEBUG)
import tecplot as tp
import sys
if '-c' in sys.argv:
    print("Opening Tecplot")
    tp.session.connect()
tp.new_layout()
# Load filename or List of filenames
file_names = ["mytest_121000.xyz", "mytest_121000.fun"]
tp.data.load_tecplot(file_names)
tp.export.save_png('loading_test.png', 600, supersample=3)
I get an error when I try
The source material says that if I want to load multiple files, I have to input a list of strings. This is not working. Any help?
Sprinkles is offline   Reply With Quote
Old   August 2, 2020, 19:17
Cool I found it!!
Oscar Alvarez
The solution was to use
path = "Desktop/AutoCore"
grid_file = os.path.join(path, "mytest_121000.xyz")
func_file = os.path.join(path, "mytest_121000.fun")
dataset = tp.data.load_plot3d(grid_filenames=grid_file, function_filenames=func_file)
I learned that the *.xyz file was a grid file and had to load it as such. I also had a function file that I loaded in as well.
file, load, pytecplot, tecplot, xyz
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 09:46
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 22:03
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
