Home > Forums > Visualization & Post-Processing Software > Tecplot
How to delete the surplus data in the tecplot
Old   July 2, 2020, 17:03
Default How to delete the surplus data in the tecplot
hitzhwan is on a distinguished road
'm working on a project where we are constantly swapping out zones from various .plt files. I have deleted zones that are no longer being used, but when I look at "Data -> Data Set Info... -> Data Set tab", I see that .plt files with all zones removed are still showing.
The load time is getting rather large, so I'm hoping to delete some of these unused data sets. Is this possible, and where would I do this?
hitzhwan is offline   Reply With Quote
Old   July 2, 2020, 19:37
novedevon is on a distinguished road
The best way to do this is not use the "append" option when loading additional data but use the replace option otherwise Tecplot will keep a log of all datasets loaded over the session. Hopefully this helps.
novedevon is offline   Reply With Quote
Old   July 3, 2020, 16:53
Default But if I use the replace method, all the plot setting I set before will restart, so i
But if I use the replace method, all the plot setting I set before will restart, so it is very time consuming, does there have any quick way to make the plot quick without setting it again?
Old   July 6, 2020, 15:14
There are a few different methods to work around this depending on some specifics of your data and your workflow. Stylesheets, the replace method, layouts, configuration files or other methods that may be more specialized to specific workflows.
If you want to go into more detail shoot an email to support@tecplot.com and we can go into more detail there.
Old   July 7, 2020, 18:19
Default I have sent email to the support@tecplot.com, could you receive it ?
Tecplot 360 2017 Release 2 manohar1487 Main CFD Forum 0 August 28, 2017 03:08
Tecplot visualization OpenFoam data: Unable to load the solution data ndtrong Tecplot 2 July 30, 2017 12:45
Run OpenFoam in 2 nodes of a cluster WhiteW OpenFOAM Running, Solving & CFD 16 December 20, 2016 01:51
[General] reading tecplot time data in a single file canopus ParaView 0 March 17, 2013 21:12
CGNS vs Tecplot Data Format LWhitson2 Main CFD Forum 3 July 1, 2011 14:50
