May 26, 2020, 16:33 |
Plt to Szl Convesion techplot
Rep Power: 7 |
I'm using tecplot with data from Converge. These data files are converted by converge in.plt. However, as it's big data file, I would like convert is in szl to improve tecplot performance, but when I'm using the "Write data" to or a script to do that, I always have the same issue : "cannot export dataset : zone 1 is unsupported type" I tried to delete this zone, but it's the same issue with all zone. Could you help me ? Thanks in advance |
May 29, 2020, 10:42 |
Antoine Ligier
Rep Power: 7 |
Hi Tmi,
CONVERGE uses Automatic Mesh Refinment and hence writes the data as Polyhedra. Polyhedra is not currently supported by the szplt format. There are a couple of options and best practices that can help you improve performance for your post-processing of CONVERGE data. Feel free to write to support@tecplot.com (or support-eu@tecplot.com if you are located in Europe), we'd be glad to help. Best regards, Antoine |
Vector arrows in techplot | Alhasan | Tecplot | 2 | October 21, 2015 16:37 |
CFX PROBLEM ???? or TECHPLOT | mohammad | CFX | 0 | September 3, 2012 22:51 |
Extract data we want from Techplot to a data file | vetnav | Main CFD Forum | 0 | July 28, 2010 21:17 |
techplot | kamal | FLUENT | 1 | August 1, 2008 10:22 |
Reading Fluent files into TECHPLOT | krishna | FLUENT | 4 | May 28, 2004 04:00 |
