ahr
Rep Power: 9 ![]() |
Hi
I have a 3d tecplot (*.plt) file (X,Y,Z coordinates). I wonder if it is possible to export the file as a 3D files such as (*.fbx), so that I can insert it into power point as a 3D object. |
Scott Fowler
Rep Power: 17 ![]() |
We don't have a direct (*.fbx) exporter. However, Tecplot 360 has a Python API (https://www.tecplot.com/docs/pytecplot/) which could be used to access the data and export to the *.fbx format.
You may also have to use the FBX SDK, available here: https://www.autodesk.com/developer-n...fbx-sdk-2020-0 |
Yogesh Nalam
Rep Power: 13 ![]() |
Can someone point me to any online resource that shows how to do this conversion? I totally donot know on how to use FBX SDK.
It will be greatly helpful. Thanks IA. |
3d plt, fbx, plt, tecplot |
Using PengRobinsonGas EoS with sprayFoam | Jabo | OpenFOAM Running, Solving & CFD | 36 | July 16, 2024 03:52 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
