Home > Forums > Visualization & Post-Processing Software > Tecplot
Particle Pathline: User Manual Doubt
Old   April 25, 2019, 06:37
Question Particle Pathline: Missing Pressure Gradient Term
Pravaah is on a distinguished road
This is regarding particle pathline calculation procedure mentioned in Tecplot's user manual. https://www.tecplot.com/documentation/
So my question is regarding the procedure adopted there:
the first step is to generate streamlines and then mention values for velocity components, mass, radius and drag coefficient.
Why pressure values are not being taken as input?
Even in the documentation, there is no mention of contribution, in particle's acceleration, by the pressure gradient.
Pravaah is offline   Reply With Quote
Old   April 26, 2019, 21:25
Dave Taflin
davetaflin is on a distinguished road
The density of the particles is assumed to be much larger than the density of the fluid, making pressure forces unimportant. See FLUENT's explanation of this here: https://www.sharcnet.ca/Software/Ans...le_motion.html
davetaflin is offline   Reply With Quote
Old   April 28, 2019, 10:41
Many thanks for reply
I had one counter question:
What you are saying is true for Fluent.
What about Tecplot? because there is no mention of any such assumption.
Why do they calculate stramlines first? Is it for inital guess of path only?
I was thinking if it gets density and velocities then it can easily calculate pressure gradients for those terms.
pathlines, pressure gradient, user manual
How to plot a single particle pathline in FLUENT shashanktiwari619 FLUENT 0 June 24, 2017 01:59
injection problem Mark New FLUENT 0 August 4, 2013 02:30
particle user routines Felix CFX 1 July 24, 2006 13:32
Particle Injection User Fortran Routine Adam CFX 5 December 13, 2005 04:16
confused about particle user source sub-routine wayne CFX 1 August 30, 2005 07:55
