Home > Forums > Visualization & Post-Processing Software > Tecplot
Video export gives empty file
Old   January 8, 2019, 13:09
Default Video export gives empty file
jackdoubleyou is on a distinguished road
I'm trying to export a video from tecplot, but every time I try it just gives an empty file, with no frames in the video. Tecplot doesn't give any error message, and it appears as if the process worked. I'm using Tecplot 360 EX 2018 R1 on a linux workstation. The data is generated by OpenFOAM and converted to EnSight format. I can manipulate the data as normal in tecplot and everything looks fine, apart from video export.
Any help is appreciated
jackdoubleyou is offline   Reply With Quote
export, tecplot, video
[swak4Foam] swak4foam for OpenFOAM 4.0 mnikku OpenFOAM Community Contributions 80 May 17, 2022 09:06
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
