Home > Forums > Visualization & Post-Processing Software > Tecplot
Some variables not loading in Tecplot
Old   September 20, 2018, 03:56
Default Some variables not loading in Tecplot
Nick Thomas
nick.l.thomas is on a distinguished road
I am running a transient solution for a vertical axis wind turbine, and when I load the .cgns files in Tecplot there is data missing from some variables. For example, I can create a contour of the x velocity, but when I try to do the same for pressure or y velocity no data loads (the contour is one color). Checking the data set info, the Var status for these missing variables is "not loaded", but loading the variables does not help.
In my .cfx file, under output control > results > output variables list, all the variables I want are listed. Likewise, under output control > export > output variables list, all the variables I want are listed there as well. When running the .res file, I can create contours of all the variables, it's only in Tecplot that the problem exists.
Any ideas what I'm missing here? This is my first attempt at a transient solution so I could be making a pretty basic mistake.
nick.l.thomas is offline   Reply With Quote
Old   October 25, 2018, 18:48
John Connell
JohnConnell is on a distinguished road
Hello Nick,
If your dataset shows the variables in the Data Set Info dialog, it is likely loaded correctly. I would check in your Data -> Spreadsheet for information about your other variables at each time step. There you can see if any data is located in your files.
If you would like us to take a look at your dataset, you can send it to us at support@tecplot.com. We could get on a call to help talk you through loading your data and getting the relevant Contour plots.
Thanks,
John Connell
Tecplot Technical Support Specialist
JohnConnell is offline   Reply With Quote
cgns, missing variables
tecplot: read UDM variables from fluent data files denis.sanga@hotmail.it FLUENT 0 July 24, 2018 06:40
Problem with importing FDS files to Tecplot and see all variables taban Tecplot 4 March 11, 2018 08:41
Tecplot 360 2017 Release 2 manohar1487 Main CFD Forum 0 August 28, 2017 03:08
Overbar for variables in axes label for Tecplot 10 babakflame Tecplot 0 November 5, 2014 15:30
Loading Cell Values in Tecplot P1361 OpenFOAM Post-Processing 3 September 16, 2014 05:02
