Home > Forums > Visualization & Post-Processing Software > Tecplot
Tecplot slice command
Old   April 26, 2018, 06:46
Default Tecplot slice command
Bereket Tsegai Habte
bereket is on a distinguished road
Hello guys, I am trying to use the slice command in Tecplot to remove an octant of a cubic microstructure and to visualise the remaining similar to the image attached.
Thanks
bereket is offline   Reply With Quote
Old   April 30, 2018, 12:17
John Connell
JohnConnell is on a distinguished road
Hello bereket,
The slice commands will not cut out an octant of your data like you have shown. However, this can be done with the Data Alter menu and Value Blanking. Because the octant is known, you can create a Blanking variable like so:
{Blank} = IF(X<=0 && Y<=0.5 && Z >= 0.25, 1, 0)
Then if you navigate to the Value Blanking dialog and turn it on for Blank equal to 1, it will blank the region X less than 0, Y less than 0.5, Z greater than 0.25.
Thanks,
John Connell
Tecplot Technical Support
JohnConnell is offline   Reply With Quote
slices
Command line program tec360 missing in Tecplot 360 EX praveen Tecplot 2 February 1, 2015 00:04
[DesignModeler] Slice command does not preserve bodies jtipton2 ANSYS Meshing & Geometry 1 July 31, 2013 12:48
tecplot 1D slice user0314 Tecplot 0 June 23, 2011 12:45
Bounded slice in Tecplot possible? Sam Tecplot 1 August 20, 2008 13:18
Tecplot Slice Alex Tecplot 2 April 28, 2006 09:28
