Home > Forums > Visualization & Post-Processing Software > Tecplot
Calculating Heat Flux across wall-boundary
Old   July 8, 2017, 22:53
Default Calculating Heat Flux across wall-boundary
The_Provost
The_Provost is on a distinguished road
Send a message via Skype™ to The_Provost
I am using Tecplot 360, and would like to calculate the heat-flux across the wall-boundary. I have tried specify equation, and calculating it using ddy() function, but it shows that the heat flux is zero, which is absurd, because the simulation shows there is definite heat transfer through the wall.
I am sure I am not calculating the heat flux in the correct way. Any help would be appreciated.
Thanks,
The_Provost
The_Provost is offline   Reply With Quote
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 22:16
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
