Please Help on advising me on Plotting of Mach Number Contour Plot with Tecplot 360 |
June 22, 2017, 13:00 |
chor kiat lau
Hi everyone,
I am very new to tecplot 360, so i appreciate everyone for their help. I would like to plot the mach number contour plot of a blade at different slices of the blade for example from the tip area, hub area and mid span. Can i check with the experts how can I do it? I have a list of values on x,y,z, rho, ux, uy, uz, P name under file .tec? I presume the rho and P are the local values, and i will need to calculate T with T=P/(rho*R) and than follow by calculating the local Mach number? Thank you if you could advise and share with me some tips. |
June 26, 2017, 13:42 |
Scott Fowler
Rep Power: 17 |
You can use Calculate Variables under the Analyze Menu to calculate both Temperature and Mach Number. You'll need to specify the thermodynamic variables in Analyze->Field Variables... first. Once you've calculated Mach Number you can add slices to your plot and color them by Mach Number.
Hope that helps. Scott |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 22:00 |
How to plot a contour from an excel file in Tecplot? | gholamghar | Tecplot | 9 | February 11, 2021 14:43 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 15:49 |
Mach number in tecplot | mhdmk | FLUENT | 1 | January 31, 2014 03:33 |
to plot Mach contour using GNUPLOT | killtimm | Main CFD Forum | 2 | December 28, 2009 12:15 |
