Home > Forums > Visualization & Post-Processing Software > Tecplot
Lambda Ci in tecplot
Old   March 24, 2017, 09:09
Default Lambda Ci in tecplot
Fabian
Fabixeneize is on a distinguished road
I'm trying to use lambda ci method to visualize vortexes on Tecplot, and I'm having some trouble with the expresion to calculate lambda Ci with Tecplots macro. One of the reasons is that my tecplot version, 360 2012R1 is not compatible with functions as "IF"
The macro reads for lci (lambda ci)
$!ALTERDATA EQUATION = '{lci} = IF ({Beta}<=0, -1 , (sqrt(3)/2)*((abs({Beta}))**(1/3) + {Q}/3 * (abs({Beta}))**(-1/3) ))'
The syntax of the expression is
{Result} = IF(Condition, expression if true, expression if false)
But would it really be -1?
Thanks for your help
Fabixeneize is offline   Reply With Quote
Old   March 24, 2017, 12:18
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
why are you using macros? I remember that Tecplot has already the lamba-2 method implemented...
FMDenaro is offline   Reply With Quote
Old   March 24, 2017, 13:37
Fabian
I think is because of the version of Tecplot I'm using.
Old   March 24, 2017, 13:41
Well, I would code in fortran the evaluation of the lambda2 function, then write data in a file and load it in tecplot to see the iso-surfaces
lambdaci lci
polyhedral mesh shown by tecplot as tetra.. manuc Tecplot 0 July 4, 2016 10:03
how to make tecplot to use only static temperature Hadi Khabbaz Tecplot 0 March 4, 2016 20:08
I created a tecplot binary file... Lupocci Tecplot 6 June 27, 2012 20:56
Problem Exporting to Tecplot Craig FLUENT 2 July 16, 2008 00:21
Tecplot can't read data file from Fluent. stephen FLUENT 8 November 21, 2001 21:27
