Home > Forums > Visualization & Post-Processing Software > Tecplot
Tecplot .plt file to cgns format
Old   February 24, 2017, 17:47
Default Tecplot .plt file to cgns format
Akshay Bagi
akshaybagi is on a distinguished road
I have a .plt file that is an output of starccm+. It has mesh and solution data in it. I want to convert this .plt file into a cgns file that has mesh and solution data again. Can anyone please tell me how to do this?
Thanks
Akshay
akshaybagi is offline   Reply With Quote
Old   February 25, 2017, 00:22
novedevon is on a distinguished road
Output it directly from Star. The direct CGNS output is better anyways. If you are running into the 64bit issue loading into tecplot try 2017R1 as it supports 64bit CGNS
novedevon is offline   Reply With Quote
Old   February 25, 2017, 02:38
Akshay Bagi
Hi novedevon,
The problem is star can only output only mesh data and no solution data. I need the CGNS file to contain both mesh and solution data. Star doesn't support that.
Cheers
Akshay
.plt, cgns, conversion, starccm+, tecplot
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 10:07
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
