Home > Forums > Visualization & Post-Processing Software > Tecplot
Periodic Boundary Condition
Old   September 20, 2016, 07:54
Default Periodic Boundary Condition
ZaheerAhmed
odho is on a distinguished road
Hi
please help me regarding data format to save the results with periodic boundary condition.
Below here are two subroutines which i am using to save data.
subroutine print_fronts1(my_Fronts,my_NumFront,nf,grank,time)
use module_grid
use module_IO
use front_lib
implicit none
type(Front), dimension(, pointer, intent(in) :: my_Fronts
integer :: my_NumFront
integer :: nf, iunit, i,grank
real(8) :: time
iunit=7
OPEN(UNIT=iunit,FILE=trim(out_path)//'/front'//int2text(grank,4)//int2text(nf,4)//'.dat')
write(iunit,*)'variables = "x","y","z"' !,"u","v","w"'
do i = 1, myNumFronts
write(iunit,"('ZONE solutiontime=',1PG15.7E2,' DATAPACKING=POINT, ZONETYPE=FETRIANGLE')")time
call print_1(my_Fronts(myFronts_IDs(i)),iunit,GammaInf, xh,yh,zh,dx,dy,dz,Nx,Ny,Nz,Ng,Nxt,Nyt,Nzt, &
xLength,yLength,zLength)
enddo
close(iunit)
end subroutine print_fronts1
subroutine print_1(this,iunit,GammaInf,xh,yh,zh,dx,dy,dz,Nx,N y,Nz,Ng,Nxt,Nyt,Nzt,xLength,yLength,zLength)
! use module_grid
! use module_IO
implicit none
type(Front), intent(in) :: this
integer, intent(in) :: Nxt, Nyt, Nzt ! total number of cells
integer, intent(in) :: Nx, Ny, Nz, Ng
real(8), intent(in) :: xLength, yLength, zLength, GammaInf
real(8), dimension(Nxt), intent(in) :: xh, dx
real(8), dimension(Nyt), intent(in) :: yh, dy
real(8), dimension(Nzt), intent(in) :: zh, dz
integer :: iunit, elem, point, p1, p2, p3
real(8) :: xp(3)
!--mm
this%AveGamma = 0.0d0
this%CountNgbr = 0.0d0
!--mm
write(iunit,"('NODES=',I6,' ,ELEMENTS=', I6)")this%PointLength, this%ElemLength
!--mm
!----compute the surfactant concentration at element corners
do elem = 1, this%ElemLength
p1=this%ElemCorner(1,elem)
p2=this%ElemCorner(2,elem)
p3=this%ElemCorner(3,elem)
this%AveGamma(p1) = this%AveGamma(p1) + this%gammas(elem)
this%AveGamma(p2) = this%AveGamma(p2) + this%gammas(elem)
this%AveGamma(p3) = this%AveGamma(p3) + this%gammas(elem)
this%CountNgbr(p1) = this%CountNgbr(p1) + 1.0d0
this%CountNgbr(p2) = this%CountNgbr(p2) + 1.0d0
this%CountNgbr(p3) = this%CountNgbr(p3) + 1.0d0
enddo
!--mm
do point = 1, this%PointLength
call GetCoords(this,xp,point,xh,yh,zh,dx,dy,dz,Nx,Ny,Nz ,Ng,Nxt,Nyt,Nzt,xLength,yLength,zLength)
!--mm
this%AveGamma(point) = this%AveGamma(point)/this%CountNgbr(point)
!--mm
write(iunit,'(6e16.8e2)') modulo(xp(1),xLength), modulo(xp(2),yLength), &
modulo(xp(3),zLength), this%AveGamma(point)/GammaInf
enddo
call write_integer(iunit,this%ElemCorner(1,elem),this%E lemCorner(2,elem),this%ElemCorner(3,elem))
enddo
end subroutine print_1
see the result attached here with.
when bubbles are boundary which is periodic the result is not good
please help me to correct this.
thanks alot
odho is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Unsteady Periodic Boundary Condition EMolina SU2 0 July 24, 2014 17:16
About periodic boundary condition. kohel_11 FLUENT 3 July 30, 2013 08:37
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
