Home > Forums > Visualization & Post-Processing Software > Tecplot
vector plot inside pipe bend
Old   August 2, 2016, 06:15
Default vector plot inside pipe bend
Prasun Dutta
pd.iiest is on a distinguished road
I want to plot dean vortices inside a 90 degree pipe bend at different section (30 degree, 60 degree etc.). The pipe bend axis rotates from x-axis to y-axis from 0 to 90 degree. I have already plotted vortices at bend outlet (90 degree) and in the downstream region by using vector plot and streamtraces option available in tecplot of x-velocity and z-velocity. But what will be the vector variables for plotting that inside 30 degree of bend section as the bend rotates about z-axis, i.e from x-axis to y-axis? Should I have to create new variables of velocity components? Hope my problem is clear to all.
pd.iiest is offline   Reply With Quote
Floating point exception after changing from straight pipe to bend Zen OpenFOAM Running, Solving & CFD 1 March 13, 2016 10:04
ICEM hexa meshing for pipe bend cghodke ANSYS Meshing & Geometry 2 July 6, 2015 04:59
Problems about phase-change simulation inside a heat pipe 6863523 FLUENT 7 October 14, 2014 11:07
Sand accumulation in a pipe bend RTHartley Fluent Multiphase 0 October 22, 2013 08:39
Frequency of fluid inside a pipe srijithbpillai FLUENT 0 April 15, 2009 13:43
