March 30, 2016, 08:44 |
extract data to tecplot chorus
吴天
Rep Power: 10 |
there is A set of 2D tecplot data。I want extract one variable from tecplot 360 to tecplot chorus,how can i do it ?
there is some Video Tutorials on youtube . but it only support date of variable's integrate. example if i want max contour value or max X, how can i extract it to the tecplot chorus? |
March 31, 2016, 14:50 |
Scott Rumage
Rep Power: 17 |
I may not understand your question, but I would like to try to clarify the purposes of Tecplot 360 & Tecplot Chorus. One would not extract a single variable from a single data set and plot it in Tecplot Chorus.
Tecplot 360 is for plotting & visualizing a single set (or a few sets) of data. So if one wanted to create a contour plot and to determine a maximum value, then they would use Tecplot 360 for this application. Tecplot Chorus is for analyzing and understanding groupings of data sets that have the same independent and dependent variables. Typically these groupings of data will have the independent variables range over a prescribed design parameter. For example, in the design of an air vehicle one might create simulations based on the independent variables of velocity, angle of attack, etc. And from these same studies, one might want to understand the dependent variables such as lift & drag. Using Chorus an engineer will organize the design study (with potentially hundreds of simulations) to enable the understanding of the resulting simulations, and then using the resulting plots and visualizations to guide the design team to the best solution or configuration. Scott |
extract data, tecplot, tecplot chorus |
Reading Additional Data Quantities from Fluent into Tecplot | fremder | Tecplot | 9 | December 16, 2016 16:35 |
Export Surface LIC data from Paraview to Tecplot? | hxaxtma | Tecplot | 1 | July 2, 2014 05:55 |
Fortran unformatted to tecplot binary | sdharmar | Tecplot | 2 | April 9, 2014 08:19 |
fluent case n data files not exporting to tecplot | krishna | FLUENT | 2 | February 18, 2007 00:24 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 18:27 |
