Home > Forums > Visualization & Post-Processing Software > Tecplot
Boundary layer transition
Old   March 6, 2016, 21:42
Default Boundary layer transition
Kumar
pksri is on a distinguished road
Dear all,
I am newbie to tec plot and please bare with my stupid questions.
I have did LE simulation over a flat plate and my main aim is to find the transition region. I am struggling to generate results using tecplot. If someone could guide me it would be of great help. The questions are
1. I would like to get a time averaged shear stress along the flat plate ( I tried analysis -> perform integration -> time strands, but the result generated was not appropriate )
2. I would like to generate the result image like the one I have attached.
If any one could give some suggestion will be of great help., especially I am more concentrated on the point 1 (about time averaged results )
Kind regards,
Kumar
pksri is offline   Reply With Quote
Old   March 29, 2016, 13:46
lihongmiao
lihongmiao is on a distinguished road
which turbulent model do you use?
lihongmiao is offline   Reply With Quote
Old   March 29, 2016, 13:55
Kumar
Large eddy simulation, Wales model
Old   August 31, 2016, 12:49
Marion
cymbourne is on a distinguished road
From what I can see in your picture, I would say that you should represent iso-contours of the Q-criterion (they can be easily computed) .
Cheers
cymbourne is offline   Reply With Quote
Old   August 31, 2016, 13:36
Kumar
Cheers
Hi Cymbourne,
Thank you so much for the reply. Do I have to create Q-Criterion during simulation or after? Do you know how to setup in Fluent?
BR
Kumar
Old   August 31, 2016, 16:00
Marion
have a look at this paper:
http://georgehaller.com/reprints/vortex.pdf
It depends on what code you are using... (I'd need more information on that) you can create it both during and after the simulation
Cheers
Old   August 31, 2016, 20:17
Kumar
Cheers
Thank you for your reply again. I am using Ansys Fluent.
boundary layer., large eddy simulation., transition boundary layer
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Boundary layer transition problem hadesmajesty Main CFD Forum 2 December 22, 2010 01:26
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
Boundary layer transition over a flat plate shraman Main CFD Forum 1 May 12, 2005 05:55
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
