Home > Forums > Visualization & Post-Processing Software > Tecplot
OpenFOAM cases with cyclicAMI in tecPlot 360
Old   January 24, 2016, 11:57
Default OpenFOAM cases with cyclicAMI in tecPlot 360
Aidan Wimshurst
Aidan is on a distinguished road
Hi Foamers and tecPlot users,
I am attempting to load an OpenFOAM 2.3.1 case into tecPlot 360 EX 2015 R1 using the standard data loader for post processing. The case loads fine in ParaView and yields no errors when running the checkMesh utility. The case runs fine and yields a converged solution after a number of iterations in OpenFOAM 2.3.1.
The domain is 120 degree periodic and hence appears wedge shaped. An outer domain is separated from an inner wedge domain by cyclicAMI boundaries. The inner domain contains a turbo machinery blade and hence a region of high mesh refinement. Given that the checkMesh utility yields no errors and the case converges fine in OpenFOAM I do not suspect the issue lies with the mesh itself.
When I attempt to load the case in tecPlot for post processing, the mesh does not appear to have loaded properly and the patches are twisted over each other. It seems as if tecPlot has difficult in interpreting the rotational cyclic boundary conditions.
Does anyone have any ideas for what might be happening or if anyone has seen a similar issue from before?
Thanks for your help guys
Aidan is offline   Reply With Quote
cyclic, cyclicami, openfoam, periodic, tecplot
how to make sample planes in OpenFoam readable by tecplot saeedi OpenFOAM Post-Processing 6 November 29, 2016 06:06
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 06:56
CFX-Post and Tecplot 360 Rogerio Fernandes Brito CFX 2 September 28, 2008 15:45
tecplot 360 vs. 10 compatibility N.R. Tecplot 6 December 12, 2007 14:23
