Home > Forums > Visualization & Post-Processing Software > Tecplot
Obtaining Maximum from a Slice
Old   June 29, 2015, 12:23
Thumbs up Obtaining Maximum from a Slice
daniel
twolf59 is on a distinguished road
Hi All,
I have a problem which I feel should be relatively simple. I import a 3D Fluent case/data into tecplot. I create a slice at a location. Now I want to find the maximum of a variable in the that slice AND its X,Y,Z location. I know there is an add on out there called LocateMinMax or something to that effect. However, that only works on windows installs; I am on Linux. Does anyone have suggestions on how I can solve this?
Thank you
twolf59 is offline   Reply With Quote
contour, maximum, minimum, slice
Dynamic mesh udf for oscillating wall QBeast Fluent UDF and Scheme Programming 3 December 17, 2020 03:03
Extracting a non-uniform slice from a 3D geometry APSK Visualization & Post-Processing 1 October 30, 2014 16:56
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 07:20
compressible flow in turbocharger riesotto OpenFOAM 50 May 26, 2014 02:47
[General] Getting the maximum slice value in Python JPW ParaView 0 July 25, 2012 05:49
