Home > Forums > Visualization & Post-Processing Software > Tecplot
multiple conditions for an if
Old   May 27, 2015, 04:10
Default multiple conditions for an if
Simon Harbeke
Hoyskipoyski is on a distinguished road
Hey.
i a wrote a macrofunction to get my variables into a desired order. This functions should only be executed if the existing variables aren't in that order. In order to control that i would like to have an $!IF with multiple conditions, like:
$!If ("|VARNAME[4]|" != "Density")||("|VARNAME[5]|" != "VelocityX")
$!RUNMACROFUNCTION "sort_vars"
$!EndIf
Unfortunately this doesn't work no matter in which combination it put brackets around the whole and/or the single conditions. One condition alone works just fine.
Perhaps anyone of you already worked around a similar problem?
I think there should be some way work around because without being able to implement multiple conditions the logic operator AND and OR would be unnecessary. Maybe using like a temporary boolean variable that evaluates the logic expression in advance?
Thanks for any help or advice! I'm still pretty new to Tecplot scripting.
Hoyskipoyski is offline   Reply With Quote
Old   May 29, 2015, 14:50
Simon Harbeke
I worked around with multiple elseif conditions. Not the best solution in my oppinion but tecplot scripting doesn't seem to support such thing as i originally intended to do.
Modeling a Fan by the Multiple reference frame (MRF) method in CFX. saisanthoshm88 CFX 11 February 17, 2021 12:30
[blockMesh] Multiple boundary conditions in one block EOC OpenFOAM Meshing & Mesh Conversion 13 November 3, 2020 02:26
Axial Fan boundary conditions HVLS Siemens 1 June 4, 2012 17:59
Fluent fan boundary conditions. aqstax FLUENT 0 April 6, 2012 01:44
initial conditions in multiple zones Ryan FLUENT 0 July 21, 2006 14:46
