sean read
Rep Power: 12 ![]() |
I'm trying to work with fluent 14.5 results in Tecplot 360, So I was importing the case and data files through the fluent data loader without a problem, but then I wanted to to some stream traces through a zone starting from an interior wall in my model, and then I realised that the interior walls had not been imported. I then tried exporting the fluent data as a tecplot data file, this way the zones were all successfully imported, however it seems that my volumes have been interpreted as surfaces because I cannot produce volume stream traces through them, and in the zone styles dialogue I can't activate streamtrace functionality (it just says n/a). I'm sure I'm missing something simple... can anyone help? |
Hi Sean,
I suspect you may have tried this, but did you check the zonestyle dialog and make sure all the zones were active? Also we updated the Fluent loader recently to address a few issues with changes in the 14.5 format and the fix is in 360 EX 2014 R2. What version are you running? Durrell Last edited by Durrell4; February 8, 2015 at 11:54. Reason: typo |
sean read
Hey Durrell,
thanks for getting back to me I checked the zones, all active, the interior walls were not showing up. I'm using 2013 R1, so maybe an upgrade would solve the issue. What I tried last night and is working for my purpose is combining the data, using the fluent data loader and then exporting the interior walls as a tecplot data file from FLUENT |
fluent 14.5, tecplot |
Cannot import ANY ICEM hex core into Fluent v6.3!! | Robert Perry | FLUENT | 11 | April 12, 2012 04:30 |
How to import Autodesk Inventor .ipt file into ANSYS FLUENT? | soetommy | FLUENT | 0 | September 27, 2011 00:35 |
How to import CAD into Fluent (Design Modeler)? | shadyenany | FLUENT | 2 | August 9, 2011 20:14 |
Import CFX def into Fluent | eric_wang | FLUENT | 0 | April 18, 2011 13:14 |
Data import in Fluent?! | Bart Horsten | FLUENT | 3 | February 22, 2010 13:05 |
