December 11, 2014, 11:53 |
Try blanking or color cutoff
Hi
The best way to "Blank" the data with no velocity is to leverage value blanking via the Plot->Blanking->value blanking. activate the 1 blanking constraint and set it to blank data where velocity magnitude is equal to Zero. If you do not what to see the color and blanking the data is not required you can change the coloring in of the contour using the color cutoff for the velocity magnitude below zero. Let me know if you would like me to post a video tutorial on the subject and I will post it for you. Happy plotting. Durrell |
December 11, 2014, 21:28 |
#3 | |
wanghuo
Rep Power: 12 |
November 24, 2015, 00:19 |
Manjura Maula Md. Nayamatullah
Rep Power: 13 |
Can I make all the variables blank for the condition of x is greater than a constant? For example I have a domain 2.4m length. Now can I make all the variables (U,V,W, vorticity etc) blank after 2.2m? Any help would be greatly appreciated. Thanks MMMN |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 12:27 |
[ICEM] Delete family part not possible | FluidCFD | ANSYS Meshing & Geometry | 6 | April 4, 2014 09:57 |
what boundary condition is proper for simulation of shock-tube low pressure part? | immortality | OpenFOAM Running, Solving & CFD | 0 | May 2, 2013 14:22 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
