November 12, 2014, 13:27 |
Linear Interpolation not working
Zeno
Rep Power: 13 |
Hello Everyone,
I would like to linearly interpolate the file attached below on a rectangular zone having the same extrema as the x/T and z/T of the file. To create the rectangular zone I do: Data --> Create Zone --> Rectangular I=350, J=350 XMin=-2, XMax=4.75 YMin=-1.5,YMax=1.5 To attach the file to the zone I do: Data --> Interpolate --> Linear but i cannot choose my dataset as a Source Zone. How can I solve this problem? The Problem arises only with Linear Interpolation. Indeed, I can do both Inverse-Distance interpolation and Kriging. Any explanation is appreciated, Thanks in advance, Z |
November 12, 2014, 19:53 |
Scott Rumage
Rep Power: 17 |
The Tecplot 360 user manual http://download.tecplot.com/360/current/360_users_manual.pdf on page 282 states:
Use the Linear Interpolation dialog to interpolate data from one or more ordered or finite element zones onto a destination zone. Irregular I-ordered data cannot be used for the source zones in linear interpolation. I believe the data set you supply has 1-D dimensionality (it is only I ordered), so Tecplot does not know how to linear interpolate from 1-D to 2-D (so it does not offer you the option). Scott |
linear interpolation, tecplot |
Help on 2D interpolation in StarCCM+ | madhuri | Siemens | 1 | May 30, 2017 04:20 |
How to avoid checkerboard? | dohnie | OpenFOAM Programming & Development | 7 | January 26, 2015 04:12 |
Heat flux BC | lfrigeri3 | OpenFOAM | 9 | February 22, 2014 12:59 |
how to modify fvScheme to converge? | immortality | OpenFOAM Running, Solving & CFD | 15 | January 16, 2013 14:06 |
Surface interpolation schemes and parallelization | jutta | OpenFOAM Running, Solving & CFD | 0 | February 25, 2010 15:32 |
