October 11, 2007, 16:00 |
Tecplot
I'm using tecplot 360. For my 3D simulation I need to calculate the momentum flux on one specified face, Tecplot has the option to pertform different types of integrations, for my case, I need to calculate the following: integration of : (density x velocity^2 x liquid_volume_fraction )(d Area) I have the data of velocity and volume fraction in tecplot but I don't know how I can make the above integration regarding the fact that the velocity is squared. Any idea or suggestion is appreciated. Thank you Sanaz |
October 11, 2007, 16:47 |
Re: Tecplot
Define a new variable {vel2} = {vel}*{vel} using the Alter Data Set -> Equation. Then integrate {vel2}. Or for that matter, just define a variable for the momentum.
Importing contour maps into Tecplot | jcostex | Tecplot | 1 | May 20, 2009 13:48 |
Problem Exporting to Tecplot | Craig | FLUENT | 2 | July 16, 2008 00:21 |
How to read tecplot file witout tecplot ? | Pol | Tecplot | 11 | March 2, 2007 07:26 |
Using Tecplot for contours display | david | FLUENT | 2 | August 23, 2005 23:37 |
Tecplot can't read data file from Fluent. | stephen | FLUENT | 8 | November 21, 2001 21:27 |
