Incorrect showing for the contour in Tecplot 360 |
August 12, 2014, 13:46 |
kang
Rep Power: 12 |
I am using Tecplot to view the results modeled by KIVA-4, and the results are in gmv format. After I load these files from `load input files - kiva load`, their contours cannot be shown properly in Tecplot ( as shown in attached Fig 1.)
Could anyone tell how i can show the contour properly? I also attached the original data files (attached as data.zip) , so you may try to load them to Tecplot and see if you can show them correctly. Thanks a lot for the help. (Note: these files are in gmv format gotten from software “KIVA”, so you should load them from the top menu of Tecplot “File 》》 Load Data Files 》》 Kiva loader”) |
Tecplot 360 2011 R2 preview with OpenFOAM data loader available for evaluation | scott_rumage | OpenFOAM Post-Processing | 50 | January 23, 2017 03:49 |
Showing contour height | flow_CH | Tecplot | 1 | July 22, 2013 12:08 |
How to plot contour lines in Tecplot 360 using Excel file | Iqbal | Tecplot | 1 | May 30, 2012 20:22 |
Importing contour maps into Tecplot | jcostex | Tecplot | 1 | May 20, 2009 13:48 |
Tecplot problem of plotting boundary in contour | mafoi | Tecplot | 1 | April 5, 2005 07:43 |
