Home > Forums > Visualization & Post-Processing Software > Tecplot
How to make the axis value change with an animation when using tecplot?
Old   August 12, 2014, 13:10
Exclamation How to make the axis value change with an animation when using tecplot?
kang
bhbuaa is on a distinguished road
I am using tecplot 360 to make an animation for a batch of data files, which are from an engine combustion simulation. However, the axis values in the legend are not change as time changes. So this makes the results shown in the animation not correct (I attached the two different time results from the animation here, and these two results should have very different pressure values, but here the axis values are same).
So i would like to ask if anyone know how i can make the axis values change for different time to make the animation correct? If you know, could you tell me how to do that?
Thanks a lot for the help.
bhbuaa is offline   Reply With Quote
[swak4Foam] some errors in compiling groovyBC in OF220 immortality OpenFOAM Community Contributions 10 April 1, 2013 04:46
Multiblock animation in Tecplot. Simon Tecplot 4 February 10, 2006 11:27
Animation by Tecplot Daniel Tecplot 1 August 2, 2005 06:13
make an animation plots from the data colopolo Main CFD Forum 4 September 30, 2003 11:45
Animation in Tecplot ryoga Tecplot 0 February 18, 2002 12:19
