Home > Forums > Visualization & Post-Processing Software > Tecplot
Missing Variables in a Contour Group
Old   August 4, 2014, 07:06
Smile Missing Variables in a Contour Group
Taiwo
Taiwo_Oni is on a distinguished road
I used Fluent Data Loader to load a data file to Tecplot but discovered that some of the variables (e.g. velocity magnitude, radial velocity, total temperature, etc) that were exported and written from Fluent to Tecplot were missing in the Contour & Multi-Colouring Details in the Tecplot.
Can somebody please help me by letting me know how to make these variables not to be missing, i.e. to make them be part of the variables that will be available in the Contour & Multi-Colouring Details in the Tecplot.
Taiwo_Oni is offline   Reply With Quote
Old   April 18, 2015, 23:49
汪双君
everlasting704 is on a distinguished road
I meet the similar problem,if you have solve the problem or have some conclusion,please give me a hand.Thanks in advance.
everlasting704 is offline   Reply With Quote
Old   March 10, 2016, 11:21
Sebastian
Ambalo is on a distinguished road
I've got the same problem. If I export Fluent data and cas files using the "Data File Quantities..." Tecplot reading all "Standart Quantities" but not the "Additional Quantities".
So it would be great, if someone can help.
Thank you
Ambalo is offline   Reply With Quote
Old   March 31, 2016, 08:45
chen_xmu is on a distinguished road
The same problem occured when I export the Custom field function from Fluent to Tecplot. Finally, I solved it through the way to export the data of the single varible by Tecplot Formart. In tecplot, the name of the varible is "unkonw varible #......." .
chen_xmu is offline   Reply With Quote
Old   October 15, 2024, 19:00
Emmanuel Quayson-Sackey
Quayson-Sackey is on a distinguished road
Please I am facing the same problem . Did anyone get the solution to this?
Quayson-Sackey is offline   Reply With Quote
availability, contour, miss, variables, velocity
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
error message cuteapathy CFX 14 March 20, 2012 07:45
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Are my IRIXbs systune parametersb setting correct lakeat OpenFOAM Installation 1 May 5, 2008 11:48
How to use q1 and ground file? zheh Phoenics 5 September 9, 2001 06:01
