Tecplot > Fluent transient single case multiple data files |
Rep Power: 0 ![]() |
hi everyone,
I have a single case and multiple data files belonging to the case file. Is it possible to animate on Tecplot? (I created animation for multiple case and data files when they are matched in pairs. Since files are huge, i have to use singe case file. ) thank you |
Tom Tranter
Rep Power: 13 ![]() |
You can load multiple fluent data files with the case file by selecting them all when adding files in the fluent data loader. File -> load files -> Fluent data loader.
Then to animate press the animate button at the top and select time. You can then change the destination to on screen or file to save the animation and also select frames per second etc. |
Aga
Rep Power: 12 ![]() |
Hi
I have the same problem you had, i.e. loading multiple files to animate. However I need to load 360 files and Tecplot hangs. Do you have any suggestions?? Thank you in advance. Alejandro Allievi |
animation, fluent, tecplot, transient |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
[General] reading tecplot time data in a single file | canopus | ParaView | 0 | March 17, 2013 20:12 |
saving Transient/Unsteady data of multiple surface integrals in single file | ankur gupta | FLUENT | 0 | February 22, 2012 13:59 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
Structure of case and data files | Frederic Nicolas | FLUENT | 1 | August 4, 2000 11:54 |
