Home > Forums > Visualization & Post-Processing Software > Tecplot
help on tecplot
Old   February 8, 2007, 09:04
Default help on tecplot
Aditya
I have a mesh file consisting vertical annulus formed by concentric cylinders and I want to view the results.
I want to extract data-line at a particular radius on particular plane (say z = constant if the axis of the cylinders is z) in tecplot
I also want to extract a "slice" which is concentric with the cylinders.
Can I do it in tecplot ? Help would be appreciated .
Importing contour maps into Tecplot jcostex Tecplot 1 May 20, 2009 13:48
Problem Exporting to Tecplot Craig FLUENT 2 July 16, 2008 00:21
How to read tecplot file witout tecplot ? Pol Tecplot 11 March 2, 2007 07:26
Using Tecplot for contours display david FLUENT 2 August 23, 2005 23:37
Tecplot can't read data file from Fluent. stephen FLUENT 8 November 21, 2001 21:27
