Home > Forums > Visualization & Post-Processing Software > Tecplot
tecplot
Old   August 18, 2006, 09:27
Default tecplot
student
Dear Sir, can any one please explain how to plot stream lines in tecplot. ( i know if i have u and v velocites contours from that i can draw stream lines which is in 2d) actually i have u,v,w velocities in 3d. now i have to plot stream lines, but stream lines are 2d so i need to select a plane and plot stream lines , but i dont know how to select one plane and then plotting streamlines . so plz tell me... thanks in advance
Old   August 18, 2006, 12:42
Default Re: tecplot
anyone
with tool>animate>ijk plane you can select desired plane
Old   August 20, 2006, 00:29
Default Re: tecplot
student
hello sir thanks for ur reply,,,, i tried but i couldnt get it plz explain briefly...
Old   August 21, 2006, 01:45
Default Re: tecplot
anyone
what version of tecplot u use? what is your data type: structured grid or unstructured?
>but stream lines are 2d so i need to select a plane and >plot stream lines note that ploting streamlines in 3d is also possible
Old   August 21, 2006, 04:35
Default Re: tecplot
student
im using structured grid, or if u give ur mail id i will send my uvw velocity contours . please
Old   August 21, 2006, 07:06
Default Re: tecplot
rt
note your mail i contact with u.
Old   August 21, 2006, 08:15
Default Re: tecplot
student
this is my mail id d_santhosh2@yahoo.com
Importing contour maps into Tecplot jcostex Tecplot 1 May 20, 2009 13:48
Problem Exporting to Tecplot Craig FLUENT 2 July 16, 2008 00:21
How to read tecplot file witout tecplot ? Pol Tecplot 11 March 2, 2007 07:26
Using Tecplot for contours display david FLUENT 2 August 23, 2005 23:37
Tecplot can't read data file from Fluent. stephen FLUENT 8 November 21, 2001 21:27
