Home > Forums > Visualization & Post-Processing Software > Tecplot
mat2tecplot
Like Tree22Likes
Old   December 20, 2018, 17:07
wen long
wenlong is on a distinguished road
You can a) Set up the field variables in Analyze --> Field Variables dialog
b)Calculate z-vorticity in Analyze -->Calculate Variables. See attached figure here. (I am using Tecplot 360 2018 R2)
Wen Long
wenlong is offline   Reply With Quote
Old   December 27, 2018, 18:53
Default update to mat2tecplot (v1.7)
  #62
wen long
There was a bug with padding for element center data, so the updated code is attached here. mat2tecplot_v1.7.zip
====How to use======
1) unizp the mat2tecplot.zip file to get mat2tecplot.m
2) Open it in MATLAB or Octave,
3) Type in the command line terminal
help mat2tecplplot
The distribution of this code does not represent any responsibility of Tecplot Inc. Use freely with your own discretion and risk.
Wen
Old   June 3, 2019, 19:01
bebo
pop go is on a distinguished road
Hi Engineers,
I'm trying to simulate fluid flow inside Lid-Driven cavity using MATLAB, and I'm using Tecplot 360 v2018.1.1.87425 on win. 10, 64 bit. And I'm facing a problem with streamtraces while plotting the contour lines the streamtraces didn't match with the contours, they appear as straight lines from the lower left hand corner with no physical meaning for that and they should be curved to show the vortexes and eddies at the corners. I'm attaching the image and the dat file
Any help would be appreciated
Thanks in advance
tecpsi.txt
pop go is offline   Reply With Quote
Old   June 3, 2019, 19:28
novedevon is on a distinguished road
You need to have variables loaded to generate the streamlines. The streamlines are being calculated by X&Y values so they are straight lines. If you include variables to represent U/V vector variables the streamlines should properly.
novedevon is offline   Reply With Quote
Old   June 4, 2019, 07:50
bebo
Thanks novedevon for the quick reply, I included 2 more variables in the dat file and they are the horizontal and vertical components of the velocity (u,v) to be able to plot streamlines properly.
Thanks a ton
Old   March 3, 2020, 07:04
Default Plotting Line Data
  #66
HolgerH is on a distinguished road
I tried to convert measured data as plain line data. I used tdata.lines.x for time and tdata.lines.v for the measured data.
Is it possible, that y and z are not "optional" as said in the documentation?
Can someone help here?
HolgerH is offline   Reply With Quote
Old   May 21, 2020, 13:11
Post
  #67
XIAOLIN is on a distinguished road
Thanks a lot! Works very well
XIAOLIN is offline   Reply With Quote
Old   October 20, 2020, 04:49
Default how to create the 2-D vector field file?
  #68
He Yuhao
heyuhao is on a distinguished road
I have matlab data with X Y and the horizontal and vertical velocity components u and v, how can I convert it to tecplot file then I can plot the vector field in tecplot. Thank you !
heyuhao is offline   Reply With Quote
