June 4, 2014, 10:50 |
#21 |
wen long
Rep Power: 14 |
Open mat2tecplot.m in a text editor, search for "magic number"
which is the version number, change to earlier version Wen |
June 4, 2014, 12:26 |
mat2tecplot.m
#22 |
nacera
Rep Power: 12 |
Hi wen,
I have a tecplot version 10, what is the earlier version of TDV that I will add it. Thanks |
June 4, 2014, 13:32 |
#23 |
wen long
Rep Power: 14 |
Try TDV010 or TDV100
June 4, 2014, 14:04 |
#24 |
nacera
Rep Power: 12 |
I have another problem when I put TDV100 and TDV010. The TDV100 give error as : "out of space while allocating var names" and /invalid header in binary datafile" and "unable to read binary datafile header.
The TDV010 give error as: unexpected end of file in datafile header |
June 4, 2014, 14:28 |
#25 |
wen long
Rep Power: 14 |
Oops, that means you would have to experiment a bit, the binary file format may have been changed from 10.0 to 11.0.
not sure what exactly your line of the magic number looks like unless you post it also try "#!TDV101" which means 10.1 or "!TDV75 " for version 7.5 notice there is a space after 75 |
June 4, 2014, 15:29 |
#26 |
nacera
Rep Power: 12 |
I've tested (TDV101 and TDV75 ), but they give the same error as TDV100. all older versions TDV105 give the same error
June 5, 2014, 12:53 |
#27 |
Scott Rumage
Rep Power: 17 |
I do believe you will need to upgrade your Tecplot license to the new version, as the option to use “Preplot” does not apply to the mat2tecplot.m application.
Preplot is used to convert Tecplot ASCII formatted data to Tecplot binary formatted data – which is not the situation for the use of mat2tecplot.m Here is a link to the product page on Preplot (and TecIO) if you want to learn more about this application: http://www.tecplot.com/downloads/tecio-library/ . BTW – Preplot is already installed on your computer in the Tecplot 360 “bin” folder. Contact Tecplot via the email -- sales at Tecplot dot com -- to get your license upgraded. Scott |
July 30, 2014, 18:43 |
#28 |
Scott Rumage
Rep Power: 17 |
Tecplot intern Devon Simpson has written a blog that provides a script and data showing how to use Wen Long’s Mat2Tecplot.m converter. The blog is located here: http://www.tecplot.com/blog/2014/07/28/create-tecplot-format-files-matlab-data/ .
Regards, Scott |
December 12, 2014, 11:38 |
#29 |
amine
Rep Power: 14 |
Hello Sarah,
i have data which is updating (iterating method) as isotherms computing in matlab(its updating until we reach the convergence creteria) my question is : how to get the last image in tecplot file (.plt)??? Thank you so much |
December 12, 2014, 17:05 |
What version of Tecplot are you using
#30 |
Hi nacera,
What version of Tecplot are you using? Durrell |
December 30, 2014, 13:36 |
how can i visualize isotherms and streamlines using this way?
#31 |
amine
Rep Power: 14 |
Could any one tell us how to use this way to visualize isotherms and streamlines in 2Dimensions. Thank you |
December 30, 2014, 13:51 |
Check out the videos at the link below
#32 | |
Isotherms can be produced via our contour groups and using a surface contour. Check out some the videos on using Tecplot here http://www.tecplot.com/products/tecp...deo-tutorials/ Best Durrell |
February 2, 2015, 09:38 |
Superpose two matlab figures or more in one figure like these
#33 |
amine
Rep Power: 14 |
Hello and thank you so much for your quick reply
what i am intresting in is how to put many contours on the same matlab's figure? like these below: look to one of these figures ,please let's choose the first one on the left, did you observe that on the first contour (dashed lines), there's another one but with (solid lines). how can i make the same thing??? NB: no way to imagesc them at the same time on the matlab code, we obtain these contours one by one .... so i thinking about export them (2 contours or more) together to tecplot wishing make the necessary post-processing treatment in order to get the same result Thanks |
February 27, 2015, 22:39 |
#34 | |
Rep Power: 16 |
I have tried to do as you but unfortunately, it failed to generate the tecplot file. My code as following: tdata=[]; tdata.Nvar=5; %number of variables tdata.vformat = 2*ones(1,tdata.Nvar); %Double precision for each variable (optional) tdata.varnames={'X','Y','Z','TEMP','TEMP_GRADIENT_ NON_UNITY'}; tdata.cubes(1).zonename='TEMP_GRADIENT_NON_UNITY'; %any name %tdata.cubes(1).zonename=eval('TEMP_GRADIENT_NON_U NITY'); %any name tdata.cubes(1).x=X; tdata.cubes(1).y=Y; tdata.cubes(1).z=Z; tdata.cubes(1).v(1,:,:,: )=TEMP; tdata.cubes(1).v(2,:,:,: )=TEMP_GRADIENT_NON_UNITY; mat2tecplot(tdata,'TEMP_GRADIENT_NON_UNITY.plt') I have gotten the following error: Error : cube 1 v 2nd, 3rd, 4th dimension must be of the same size as x, y, z To your knwledge, my domain is 201*201*201 |
February 28, 2015, 15:45 |
#35 | |
Rep Power: 13 |
It seems that the sizes of your arrays are not the same. Here is the error display lines in the script: if(Imax_v~=Imax || Jmax_v~=Jmax || Kmax_v ~= Kmax) s=-1; display(['Error : cube ' int2str(icube) ' v 2nd, 3rd, 4th dimension']); display([' must be of the same size as x, y, z']); Are you sure that your arrays (including x, y, z) are all 3D with the same size? |
March 1, 2015, 03:47 |
#36 | |
Rep Power: 16 |
%TEMP_GRADIENT_NON_UNITY = strcat(outputAddress,TEMP_GRADIENT_NON_UNITY_name) ; %The output name and address tdata=[]; tdata.Nvar=5; %number of variables tdata.vformat = 2*ones(1,tdata.Nvar); %Double precision for each variable (optional) tdata.varnames={'X','Y','Z','TEMP','TEMP_GRADIENT_ NON_UNITY'}; tdata.cubes(1).zonename='TEMP_GRADIENT_NON_UNITY'; %any name %tdata.cubes(1).zonename=eval('TEMP_GRADIENT_NON_U NITY'); %any name tdata.cubes(1).x=X; tdata.cubes(1).y=Y; tdata.cubes(1).z=Z; tdata.cubes(1).v(1,:,:,=TEMP; tdata.cubes(1).v(2,:,:,=TEMP_GRADIENT_NON_UNITY; mat2tecplot(tdata,'TEMP_GRADIENT_NON_UNITY.plt') |
March 1, 2015, 11:14 |
#37 |
Rep Power: 13 |
What I see here is that X, Y, Z are 201*1, you need them to be 201*201*201 like TEMP. First, use "meshgrid" function to convert X, Y, Z to rectangular grid. It should work then.
March 1, 2015, 15:52 |
#38 |
Rep Power: 16 |
March 24, 2015, 17:21 |
error in this line: function name(inputs)
#39 | |
amine
Rep Power: 14 |
Thank you for the good explanation! i tried this but did'nt work!!! function name(inputs) ------> error in this could you show us a program as an example, where did you write this part of program in your code??? Thank you again. Quote:
April 9, 2015, 17:14 |
#40 |
wen long
Rep Power: 14 |
lbmagis
You seem to not understanding that: tecplot data file does not contain information about "contours", it is designed to have the data that the contours should be based on. So instead of trying to put "contours" into the data file, just put in the original data. Contours are viewable once you have the data file in .plt format and open it in tecplot software. Plus: post your code directly so that we can help Wen |
