April 24, 2012, 16:59 |
tangential velocity visualization in tecplot
Hassan
Rep Power: 17 |
How can i plot the tangential velocity vector. (velocity vector that is perpendicular to the main flow) in tecplot.
I have u, v and W . W is the velocity in the axial direction. (the data is 3D) but ofcourse the tangential velocity vector plot will be in 2 d as i am trying to visualise it at different planes of the flow. I can slice the whole problem using tecplot .. thts not a problem.. i can see the u, v and w velocity contours on that particular extracted slice as well easily.. only problem is how can i see the vector plots for either u or v on that 2D slice. regards |
April 27, 2012, 20:15 |
Scott Rumage
Rep Power: 17 |
There was a discussion on TecplotTalk on a related issue that may be of help to your question. Here is the link to it: http://tecplottalk.com/viewtopic.php...ght=tangential
Hope this helps, Scott |
Tangential velocity | Jan | FLUENT | 2 | August 1, 2018 17:06 |
OpenFoam Tangential and Axial Velocity | robyn | OpenFOAM | 2 | August 6, 2011 06:46 |
Cylindrical coordinate system - tangential velocity | alessio.nz | OpenFOAM | 2 | December 7, 2010 06:07 |
Cyclone Tangential Velocity ... | Abdul | FLUENT | 2 | August 13, 2008 01:07 |
tangential velocity on a velocity inlet in 2D | bretti | FLUENT | 0 | July 3, 2007 09:42 |
