Local numerical anomalies in fluent flow field |
September 14, 2023, 23:02 |
yzw
Rep Power: 3 |
Friends, when I use fluent to calculate ventilation and heat dissipation in equipment rooms, the flow field results always show numerical anomalies near the outlet. When the speed at the inlet is only 4.5m/s, the speed near the pressure outlet reaches 30m/s. However, other areas of the flow field do not have this problem. I use structural grids, and the quality of the grids is also reasonable. What is the reason for this phenomenon and how to correct it
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
unable to run dynamic mesh(6dof) and wave UDF | shedo | Fluent UDF and Scheme Programming | 0 | July 1, 2022 17:22 |
Could Fluent initialize flow from time-average field data? | hongfu2233 | FLUENT | 7 | February 15, 2017 04:10 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
