Home > Forums > General Forums > System Analysis
Solution of a "simple" linear system
Old   June 21, 2023, 13:32
Default Solution of a "simple" linear system
Matthew
hunt_mat is on a distinguished road
Suppose I have the linear system:
rho_t+Urho_x+rho_0v_x=0
v_t+Uv_x=Dv_xx+aT_x
T_t+UT_x=kT_xx+bv_x
This is a mixed system of equations, one hyperbolic and two parabolic. I thought about upwinding the first-order derivatives and doing central difference for the second-order derivatives. The domain is for 0<=x<=1, and t>0.
The method I used failed completely, I was using explicit Euler, with a low CFL number to get convergence, but the results were haywire.
Any suggestions on how to get started?
hunt_mat is offline   Reply With Quote
cfd, mixed type
2way FSi, Initialize with steady solution, Fluent, Transient Sturcural, System Coupli mmkkeshavarzi FLUENT 1 June 28, 2024 08:03
overflow error in linear solution tsh850227 CFX 1 March 27, 2017 08:13
2nd Order Convergence Problem for 3D Airfoil turkmengokce OpenFOAM Running, Solving & CFD 1 September 10, 2015 08:20
error on turbulence scheme immortality OpenFOAM Pre-Processing 11 August 21, 2013 09:45
Use "bounded" in scheme or not to use? immortality OpenFOAM Pre-Processing 0 June 11, 2013 17:20
