Home > Forums > General Forums > System Analysis
Transient Heat Transfer | Simple One-Layer Wall
Old   January 14, 2022, 04:37
Default Transient Heat Transfer | Simple One-Layer Wall
Khan
HumanistEngineer is on a distinguished road
Hello All,
I try to build a transient heat transfer model for a simple one-layer wall by use of the Resistance-Capacitance (RC) approach. However, the transient temperature distribution shows weird numbers in time. Would you please check my approach and code?
Heat balance for each capacitance can be written as:
Forward-Euler Discretization (one-dimensional) gives:
At each time step this calculation procedure is run:
Here is the Python code to calculate the temperature distribution in time:
import numpy as np
""" Input Parameters """
# Wall
height_w = 3        # [m]       height of the wall
wide_w = 5          # [m]       wide of the wall
thick_w = 0.3       # [m]       thickness of the wall
volume_w = height_w * wide_w * thick_w  # [m3] volume of the wall
area_w= height_w * wide_w               # [m2] wall area
# Room
deep_r = 4          # [m]       deepness of room
volume_r = height_w * wide_w * deep_r # [m3] volume of the room air
# Initial Temperature
T_in = 20           # [°C]      indoor temperature
T_out = 2           # [°C]      outdoor temperature
# Thermal
h_in = 8           # [W/m2K]   heat transfer coefficient (indoor)
h_out = 15          # [W/m2K]   heat transfer coefficient (outdoor)
# see: Balaji NC et al. Thermal performance of the building walls
k_w = 0.811         # [W/mK]    thermal conductivity (brick)
rho_w = 1820        # [kg/m3]   density (brick)
Cp_w = 880          # [J/kgK]   specific heat capacity (brick)
# Air
rho_a = 1.204       # [kg/m3]   density (air at 20 °C)
Cp_a = 1006         # [J/kgK]   specific heat capacity (air at 20 °C)
""" Preliminary Calculations """
delta_t = 1         # [s]
C_a = rho_a * Cp_a * volume_r   # [J/K]
C_w = rho_w * Cp_w * volume_w   # [J/K]
R_in = 1 / (h_in * area_w)      # [K/W]
R_out = 1 / (h_out * area_w)    # [K/W]
R_w = thick_w / (k_w * area_w)  # [K/W]
# print('R_in = ',R_in)
# print('R_out = ',R_out)
# print('R_w = ',R_w)
""" Numeric Constants """
A = np.zeros( (4, 4) )
A[0][0]=1+delta_t/(C_a*R_in)
A[0][1]=-delta_t/(C_a*R_in)
A[1][0]=4*delta_t/(C_w*R_in)
A[1][1]=1-4*delta_t/C_w*(1/R_in+2/R_w)
A[1][2]=8*delta_t/(C_w*R_w)
A[2][1]=4*delta_t/(C_w*R_w)
A[2][2]=1-2*delta_t/C_w*(2/R_w+2/R_w)
A[2][3]=4*delta_t/(C_w*R_w)
A[3][2]=8*delta_t/(C_w*R_w)
A[3][3]=1-4*delta_t/C_w*(2/R_w+1/R_out)
B = np.zeros((4,1))
B[3][0]=4*delta_t*T_out/(C_w*R_out)
""" Numerical Simulation """
T_init=np.ones((4,1))*15
for i in range(1):
    T=np.matmul(A,T_init)+B
    T_init=T
HumanistEngineer is offline   Reply With Quote
Old   January 15, 2022, 06:54
Khan
I found the error:
The first heat balance shall be replaced with:
C_in*(dT_in/dt)=- (T_in - T_w1) / R_in
Old   July 29, 2022, 21:03
Agustín Villa
agustinvo is on a distinguished road
If you are using Python you could use Scipy to solve your state-space equations.
agustinvo is offline   Reply With Quote
Heat transfer between wall and air in Fluent jimmy871013 FLUENT 6 April 27, 2018 03:00
heat transfer through rotating metal wall groonm CFX 0 September 12, 2016 11:20
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Radiation interface hinca CFX 15 January 26, 2014 18:11
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? rogbrito CFX 1 January 29, 2012 18:48
