Home > Forums > General Forums > System Analysis
Gas turbine blade cooling
Old   July 10, 2019, 05:55
Unhappy Gas turbine blade cooling
sagnik mukherjee
Sagnik648 is on a distinguished road
I am currently working on gas turbine blade cooling design where inside a turbine blade a cooling channel is incorporated. The cooling channel is made of a single pipe system which is recirculate cooled air inside the turbine blade.
Both inlet and outlet of the cooling channel is present at the base of the blade profile.
The blade is of dimension around 120mm span and 160mm tall.
Material- blade: N155
coolant: air
Simulation is being done in ansys fluent 18.2
General solver type set at pressure based, velocity formulation- absolute and time- steady.
For the initial run viscosity model taken as laminar and energy model ON.
Boundary condition imposed
inlet air of gas turbine section: Temp- 1100K Velocity- 265m/s Pressure-101325Pa(Gauge Pressure- 0)
coolant inlet: Temp-500K Velocity- 30m/s Pressure-101325Pa(Gauge Pressure- 0)
With the initiation of calculation only, divergence is occuring in the AMG solver. Any suggestion or help would be highly appriciated.
Sagnik648 is offline   Reply With Quote
Need help in simulation of gas turbine blade film cooling diwakar FLUENT 1 November 8, 2020 10:43
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
[Other] Design gas turbine blades with film cooling and cooling Impingement in Ansys 12.0 pedrin84 ANSYS Meshing & Geometry 7 February 2, 2013 12:52
Wind Turbine Blade rotation mmd_knr FLUENT 1 August 8, 2012 15:52
film cooling in gas turbine blade ponnusamy Main CFD Forum 5 January 25, 2011 17:24
